XJR - how much toe-in?
Old Aug 6, 2016 | 05:52 PM
Mark SF's Avatar
Default XJR - how much toe-in?
Since I changed the front balljoints on the XJR, the steering has been a little "darty". So I checked today, and I had 1/16" total toe out at the front, and changed it to 3/16" toe in, which is right at the upper limit, I think (max is 0.42 degrees).
So I was wondering, has anyone experimented much with the toe-in, and how much is preferred? Most of my driving is highway so I like it to be directionally stable without steering input.
Old Aug 6, 2016 | 08:46 PM
Highhorse's Avatar
I just had mine aligned and had the spec sheet and can't find it now...arrrgh. Anyway, what width and type wheel/tire combo are you running? The wider the combo, the more nuts on you need to be. A narrower combo has more forgiveness. Caster is important, but Camber is very important also, you can ruin a any setup with camber out, especially if the rear needs shimming.
Old Aug 7, 2016 | 12:34 AM
avern1's Avatar
Attached is what i think you are looking for it is all of the caster, camber and toe-in specs for the XJR.
File Type: doc
Old Aug 7, 2016 | 12:45 AM
ericjansen's Avatar
There has been a discussion some years ago, on using a spreader bar on the front wheels during the toe-in setting, taking out any play, and be sure the toe-in setting is correct under real-life conditions.
This was all advocated by a member called "Brutal", a very knowledgeable guy.
I followed his instructions when I installed new tires, and it seems to prevent the extreme wear on the inside of the fronts which some of us experienced.
To each its own on following this, but it did good to me.
Old Aug 7, 2016 | 10:45 AM
Mark SF's Avatar
Thank you for the specs. They have quite a broad range for toe-in, from pretty much straight ahead, to about 3/16" toe-in, so I am interested in understanding what the best setting is within the allowable range.
Right now I am at the upper limit of 0.42 degrees.
jfleming
XJ40 ( XJ81 )
Apr 10, 2016 12:42 AM
robearner
Apr 2, 2016 03:51 PM
vincent661983
Apr 2, 2016 12:59 PM
last2letUdwn
Jul 8, 2007 05:37 PM
XType750
Jan 22, 2007 12:29 AM
