XJR ignition coil connectors
Old Dec 9, 2015 | 01:56 AM
Megawatt's Avatar
Default XJR ignition coil connectors
I was wondering if anyone had this same problem with 2000 xjr: Ignition wires from harness to each 4 pin connector: under the driver side "JAGUAR" coil cover section only... all wire (4 x 4 =16 total) insulation has broken down and is now brittle and/or cracked looks like due to heat.
I would like to rewire without buying a new engine management harness but can not find where to get new 4 pin connectors. I know Audi/VW has connector problems and they sell repair kits (pic included)XJR ignition coil connectors-audi-connector.jpg
Anyone know the name or part# for my 2000 xjr 4-pin connectors?
Or where to buy or compatible connectors?
Jon
