XJR J-gate shifter issue
Old Dec 8, 2015 | 01:49 PM
autocad23's Avatar
Default XJR J-gate shifter issue
Question about my '03 XJR. I've had the car a couple months now and for the first time tried to slide the shifter over from Drive to pseudo-manual and it won't slide over and out of 'D' no matter if I'm stopped or driving. Is there a trick I'm missing or do I have some linkage issues? Probably won't use the "manual" mode much, if at all, but I'm curious as to what's up.
Thanks,
Kevin
Milwaukee, WI
Old Dec 9, 2015 | 01:39 PM
Daim's Avatar
Seems like a setup or linkage issue. Mine just slips over with ease (and is used daily).
My old X300 needed a lot of force to move the stick over.
Old Dec 9, 2015 | 02:30 PM
greverrr's Avatar
It normally slides over very smooth. Here is a problem to check that I have fixed in the past on both and xjr and xkr. The dust/dirt sheild that rotates with stick (round plastic plate with plastic black toothbrush looking bristles) sometimes will crack someway or another and it jams up the manual side of the j-gate. Look down with a flash light while moving the stick (with key in ignition and car not running) and see if you can see a physical obstruction. It will look like your stick is hitting a black plate where it seems it should slide to manual mode. If that is the case, remove gear knob, remove the trim, unscrew/bolt mechanism and usually the broken guard will slide out with some tinkering and luck. From then on don't eat any everything bagels around the j-gate because there is no more protective barrier to guard falling poppy seeds
perfectson
Apr 3, 2019 02:42 PM
Bret_T
Jan 8, 2016 05:57 PM
daro31
Nov 27, 2015 09:15 PM
BlacXJRcat
Nov 19, 2015 03:44 PM
rfcpatrick09
Nov 12, 2015 11:11 PM
