XJR Knock Sensor Replacement
Old Aug 10, 2017 | 06:32 PM
David B's Avatar
Default XJR Knock Sensor Replacement
Hello, I've got to replace the knock sensor on my 2000 xjr and I was wondering if anyone had any tips or advice. I would like to do whatever I can
since the supercharger has to come off and replace the hoses that run under it.
Anything else I should replace while I'm at it? Just replaced fuel pumps,filter, and spark plugs. Not a lot of fun, that gas tank sure is sharp, but she's my girl.
Thanks everyone.
Old Aug 10, 2017 | 08:09 PM
Highhorse's Avatar
Highly recommend a Search (top right), do one for x308 supercharger hoses or similar and you'll get a few hundred threads to review. Same goes for the Knock Sensor. Ad this to your favorites, you'll not regret it and you can search there also... JagRepair.com - Jaguar Repair Information Resource
Old Aug 10, 2017 | 09:32 PM
JBzXJ40's Avatar
Definitely the heater hoses.....
Old Aug 12, 2017 | 01:39 PM
xjr2014_de's Avatar
Heater=valley hoses, both knock sensors, all small coolant hoses (throttle body, EGR valve), Norma Quick Fit three way connector of heater return hose (gets brittle when ageing), supercharger oil and coupler. And I replaced all gaskets, O-rings and seals that I came along.
Below's a list of what I've replaced (sorry for being partly in german). It's for an MY2000 XJR with VIN F23xxx, please check jaguarclassicparts for correct part no.
SC oil and coupler
2 x LNE1692AA Knock Sensor 2 x NCC3018AB Gasket Inlet Manifold 2 x NCC3020AA Gasket Inlet Manifold 2 x C2C11477 Seal NCC7754BA Gasket Induction Elbow NNE3021AC Gasket Throttle Body Adaptor NCC7735BA Seal Supercharger 4 x AJ810511 Verbindungselement - Nockenwellenabdichtung JHC301720 Schlauchschelle AJ87634 Heizungszulaufschlauch NNE3946CA Rücklaufschlauch - Heizung
AJ811638 coolant hose
KSC137624 O-Ring 4 x JHC301621 Schlauchschelle NCA4771DA Dichtring - Abgasrückführungsleitung AJ88560 Dichtring - Abgasürckführungsventil AJ89646 Dichtungsscheibe NNE3246BA Kühlerschlauch-Zulauf Drosselklappengehäuse
NNE3247BA Kühlerschlauch Drosselklappengehäuse an Abgasrückführungs-Ventil (AGR-Ventil)
Old Aug 12, 2017 | 04:30 PM
Highhorse's Avatar
Definitely need to check in here, https://www.jaguarforums.com/forum/x...k-links-20090/ ...its got everything from Knock Sensor replacement to Transmission repair. JimC put a lot of time into gathering the info for us other members, may as well make it worth his while.
