XJR overheating problem
Old Nov 20, 2016 | 08:52 PM
Bigredjaguar's Avatar
PROBLEM SOLVED!
Some dum@ss who owned the car before me put the thermostat in backwards. Now everything works fine. some people should not work on their own cars.
Old Nov 21, 2016 | 01:44 AM
JagV8's Avatar
Ouch - but at least it's fixed!
Old Nov 21, 2016 | 02:21 AM
ericjansen's Avatar
Good catch after all ...
Old Nov 21, 2016 | 08:48 AM
Rpach10115's Avatar
Originally Posted by Bigredjaguar
PROBLEM SOLVED!
Wow, that's kinda hard to do and not have it leak. My thermo has an intergrated rubber gasket that fits into the groove in the housing. It's almost kinda impossible to install this backwards.
Old Nov 21, 2016 | 09:12 AM
JTsmks's Avatar
Don't worry, some PO's manage the impossible!
Old Nov 21, 2016 | 03:02 PM
omgimali's Avatar
No. only if it needs it.
You WILL have to top it off though as you will lose some in the dis-assembly process.
Same as the water pump?
Old Nov 21, 2016 | 05:35 PM
Rpach10115's Avatar
Water pump = full change.
Thermo coolant change not necessary unless it needs it.
I would change it anyway.
Old Nov 21, 2016 | 07:01 PM
  #28
omgimali's Avatar
Does the water pump go bad on these cars?
Old Nov 21, 2016 | 07:06 PM
nilanium's Avatar
Some model years (i dont know if all) came with water pumps with plastic vanes, which can sometimes break off apparently. I did mine at 98k and the impeller looked very good, though I don't know if it had been changed before. You can replace it with a pump with a metal impeller and leave it for probably the lifetime of the car..
Old Nov 21, 2016 | 07:28 PM
  #30
omgimali's Avatar
thanks/
Old Nov 21, 2016 | 07:33 PM
  #31
ericjansen's Avatar
As far as I know it is only the 1998 models which sometimes had the problem.
I just replaced mine.
The vanes still looked like new, but the bearing was tight and made some noise.
A replacement Airtex only runs for ~$33 at Rockauto, a no-brainer.
More Information for AIRTEX AW4124
