Xjr pulling left.. Tracking?
Old Mar 27, 2021 | 01:59 PM
owas's Avatar
Default Xjr pulling left.. Tracking?
I've finished putting my jag back together,
Every joint and bushing is new now and I had it tracked, but its still pulling to the left,
Do my measurements look like they would cause the car to veer to the left or should I be looking elsewhere?
Old Mar 27, 2021 | 03:50 PM
Addicted2boost's Avatar
The 2 easiest things to do...
1) Make sure all tire pressure is good. Don’t assume it was already done before the alignment.
2) If the tire pressure was good, rotate the two front tires side to side. See if it still pulls left.
Old Mar 27, 2021 | 04:18 PM
owas's Avatar
I did check the pressures and flip the tires around, no difference unfortunately.
Doesn't seem to be affected by different roads, a constant pull if you let go of the wheel.
Old Mar 27, 2021 | 05:07 PM
Did you have all the ball joints and bushings replaced because the car was pulling left prior to all the work done?
Old Mar 27, 2021 | 05:31 PM
owas's Avatar
No pulling beforehand, just rebuilt both subframes with all new parts, everything torqued up to spec ect
Obv tracking was way out afterwards, had it set up at an alignment shop, much better but the pull is there
Old Mar 27, 2021 | 07:56 PM
nilanium's Avatar
Does all new bushings include the "vee mounts" and the front subframe rearward bushings?
Old Mar 27, 2021 | 09:27 PM
owas's Avatar
Yup both replaced
LongJohn
Aug 29, 2023 01:27 PM
Isoruku
Sights N Sounds
Nov 13, 2018 09:56 AM
Gufo62
Dec 1, 2017 03:58 PM
Mike2017XF
Jan 30, 2017 01:33 PM
al_roethlisberger
Apr 10, 2014 09:00 PM
