XJR Rear Muffler Repaired Today
Old May 25, 2013 | 12:26 PM
Munro's Avatar
Default XJR Rear Muffler Repaired Today
Just to share a bit of experience.
On my 2001MY XJR the rear muffler (silencer) broke clean off the exhaust pipe many months ago. It hung down a bit, but did not affect performance at all, and did make the car sound a bit more meaty...the thing I least like about the XJR is the lack of gut rumbling noise when pressing on. The car can be a beast, but does not sound like one.
Anyway, today I lined it back up and re-welded the carbon steel pipe to the stainless steel muffler (original Jaguar muffler). Access was a little tight one side, and partly overhead welding so not the prettiest weave in the world...but it is strong, lines up well, and now slightly quieter (never mind).
I believe the muffler to be 410 stainless (11-13 chrome) as it is ferritic (and so magnetic). I was a bit worried about its weldability, but it was fine using 0.6 mild steel wire on a MIG with Argoshield Light gas. Good weld pool, flowed well, very little spatter. I'd bought some 300 series austenitic stainless wire and already have a small spool of Inconel wire (v expensive)...but I did not need these, and need not have worried about it.
Long term, that mild steel weld consumable may suffer some preferential weld corrosion, but I'd expect it will last 5 years or so.
PS I did disconnect both terminals from the battery before welding...I was nervous that would create some electrical gremlins when I hooked it back up but nothing to note so far.
One more job off the list then. Happy Motoring.
Old Jun 13, 2013 | 01:14 AM
avt007's Avatar
Good info. I'm about to try the same repair.
JarodL
Mar 7, 2024 01:39 AM
davidladewig
Sep 3, 2015 06:32 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
