XJR Supercharger snout removal
Old Jul 23, 2016 | 08:14 AM
V8esprit's Avatar
Default XJR Supercharger snout removal
ok so I need to remove the front snout for an upgraded snout fitted with a 10% pulley. I have read that the supercharger has to be removed to do this! seams a lot of work and was wondering why it can not be removed with supercharger still fitted? looking at the exchange snout in the box all the mounting bolt holes look straight forward to get at so what am I missing? what stops it coming off in situ?
Old Jul 24, 2016 | 01:02 PM
80sRule's Avatar
The bottom holes are inaccessible with the SC in the car.
It's really not too bad to remove using the PDFs from here (I see you posted there):
https://www.jaguarforums.com/forum/x...f-files-58889/
Plus while it's off, you can throw a few bucks ($91) and almost completely rebuild it:
Fits Jaguar XJR XKR M112 Eaton supercharger Rebuild Needle Snout Bearings Seal | eBay
I've used that exact kit on my car.
My dad took my SC snout to work and turned it down nicely on a lathe so I was able to press on my 10% pulley with ease. He took it down to where there was a bit less than a 2mm diameter difference between OD of snout and ID of pulley, so about 1mm gap between the pulley and snout all around. I was able to reuse my SC Belt.
I also recommend doing bearings in the accessory and sc belt drive pulleys. It's the same bearing in all 4 (SC tensioner pulley, SC idler, Acc tensioner pulley, Acc idler) and nice cheap and easy to do.
https://www.amazon.com/6303-2RS-Bear...+Ball+Bearings
Like your Esprit, these cars REALLY benefit from doing "while you're there jobs". I'm hugely partial and have looked for a while at getting a Steven's Esprit, probably a Turbo SE/S4/S4S. Cool cars!
Jandreu
Apr 14, 2016 02:32 PM
wa3ra
Apr 12, 2016 07:40 PM
al_roethlisberger
Apr 9, 2016 03:50 AM
hisport
Apr 3, 2016 07:34 PM
IronCobra
Feb 11, 2007 12:01 AM
