xk8 rims on an xjr?
Old Mar 10, 2008 | 04:49 PM
H20boy's Avatar
Default RE: xk8 rims on an xjr?
Found this, not sure if accurate or not.
1998 Jaguar
XK8
Bolt Pattern: 5x120.65
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
2000 Jaguar
XJ
Center Bore: 73.9
Hardware:1/2 Lug
Offset: 15-25mm
So, in this case, yes. I have read other locations (roadfly) that the XK and XJ do have similar bolt patterns, but mostly the 2003 model years and under...older models.
Old Mar 10, 2008 | 06:26 PM
jag_genius's Avatar
1997-2003 xk and xj have same bolt pattern .. the same as the older jags as well.
Old Mar 25, 2008 | 05:22 PM
H20boy's Avatar
Jag-g, will the 2007 Senta wheels fit on my '03?
Old Mar 25, 2008 | 06:02 PM
bmw745ion19s's Avatar
hey h20 im not sure if they will but i think i have sene them before, although with the cost the way they are id just leave yours alone!
Old Mar 25, 2008 | 06:13 PM
FactoryJaguarTech's Avatar
$5k for the Sentas.
They will fit, but remember they are different sizes front to rear. If you were going to use them on yours, I would buy 4 fronts and install them all around.
Old Mar 25, 2008 | 06:37 PM
H20boy's Avatar
Mine are currently staggered, 19x8 and 19x9. I was thinking of going with these knockoffs. 0.5" wider than my current Apollos.
Old Mar 25, 2008 | 06:54 PM
H20boy's Avatar
correction, 19x8 and 19x9s, drop the 0.5
An extra 1/2 inch should be ok, right, pending I adjust the new tire size accordingly. What do you techs think?
Old Mar 25, 2008 | 07:18 PM
I am trying to remember now.......I will see if we have a set laying around and put them on an 03/04 xk. That will tell you for sure. Only real way to tell is real world practice.
Old Mar 25, 2008 | 07:22 PM
H20boy's Avatar
let me know what you find out. I'll do more research, and if any other techs have the opp to 'test' a Senta wheel/tire combo on an 03-04-05 yr model, please do.
Old Mar 25, 2008 | 07:54 PM
jag_genius's Avatar
the bolt pattern is different.. from a 07 xk senta wheel to a 2003 xk .
Old Mar 25, 2008 | 08:16 PM
H20boy's Avatar
oh boy, that could spoil the whole party... thanks genius.
Old Mar 25, 2008 | 08:32 PM
H20boy's Avatar
Looks like could be right, and bummer...
07 - 08 XK bolt pattern = 5 x 4.25 (same as 5 x 108)
97 - 06 XK / XJ bolt pattern = 5 x 4.75 (same as 5 x 120.65)
sound correct?
Old Mar 26, 2008 | 05:24 PM
lol....was in a daze not thinking straight.
2002+ X, 2003+ S, 2004+ XJ, 2007 XK have same bolt pattern.
I did attempt to lift a senta on an 05 today....much to the amusment of my fellow vermin. Tried to explain that you gotta try sometimes.....lol
Old Mar 26, 2008 | 06:22 PM
H20boy's Avatar
you da man for trying Stu...I mean FJT. Much appreciated, will repair my curb rash (aka zippers) and stick with the Apollos.
Old Mar 26, 2008 | 06:56 PM
jag_genius's Avatar
sorry to ruin the party lol
Old Mar 26, 2008 | 08:42 PM
It ain't a party til someone breaks a nail.
DrTripp
Mar 22, 2020 09:33 AM
slojotaa
Oct 16, 2019 10:22 AM
2010 Kyanite XFR
Feb 16, 2016 11:40 AM
lickahotskillet
Oct 18, 2015 09:51 AM
Matei Dima
Oct 8, 2015 11:45 AM
