yet another "stuck in Park" Issue with complications
hello Jag owners. Help!!
2001 Xj8L, stuck in park. Also, remotes are inoperable, passenger windows won't roll down, memory seats do nothing, and the steering wheel won't extend. Hard reset does nothing. Can someone point me to the correct fuse or module? All fuses in rear heelboard box appear good.
Chris
Chris
I can bypass the trans interlock and drive the car. Door key lock will roll down driver's window only. map lights work, radio works. A/c works. Blinkers, windows, trunk switch,door lock dash button and memory seats non functional. Worked great yesterday. Checked all fuses in trunk box, all ok. did another hard reset, no joy.
Have you had a look at the wiring diagrams for a common earth? Ground points on these are notorious.
webshark
Sep 4, 2016 11:13 AM
