ZF 5HP24 rebuilt. Lessons learned
Old Feb 29, 2020 | 09:32 AM
jacksjags's Avatar
Default ZF 5HP24 rebuilt. Lessons learned
Hi all, I want to share my experience in rebuilding my gearbox. It’s the ZF 5HP24 and the car is the base 3.2 l version from 2001. Car was driving fine before the rebuilt. No fault at all. But knowing the possible failures I was not confident keeping on driving not knowing the condition and fearing instant death one night in the middle of nowhere. A Sunday... on a highway with the wife pissed off at my side. That’s the scenario right? So, I figured: change the A drum for the new design, change the pressure regulator, speed sensors, solenoids and all gaskets and I should be good. Well, I learned the hard way a complete cleaning will create a mud slide that will likely shoot the torque converter AND the pump. So lesson was: don’t refit an old torque converter EVEN IF IT WORKED FINE BEFORE. You can’t purge it clean and the new oil will clean and clog it after a short while. So I lost my pump in the process. That advice applies if the transmission oil has not been regularly changed. But that’s most cars. Cheers!!!!!
fluty
Dec 27, 2018 05:10 PM
Britax
Mar 25, 2016 11:50 AM
XJRJeff
Oct 23, 2011 05:35 PM
marciano
Jun 17, 2010 04:28 PM
Namor
Sep 14, 2009 08:03 AM
