ZF5HP24 transmission fluid cooling line thread tap size
Old Jan 29, 2010 | 11:20 PM
jeiiomix's Avatar
Default ZF5HP24 transmission fluid cooling line thread tap size
I just replaced my forward A drum and ordered new cooling lines for my ZF... When I took out the old ones, some of the threads from the lines got caught in the threads on the case. Can someone tell me the size tap I will need to clean out the threads? Shot in the dark here.. Im hopin someone out here knows the answer!
Old Feb 1, 2010 | 10:28 PM
jeiiomix's Avatar
I actually found out in case anyone else wants to know... Its a standard O2 sensor thread size (or 18mm spark plug) 18mm 1.5 chaser. Oxygen sensor thread tracer tool cost 7 bucks and I'm back in biz..
Old Feb 2, 2010 | 02:24 PM
Dan R's Avatar
What is the procedure for changing an A drum?
Old Sep 15, 2010 | 01:00 PM
AlexXK8's Avatar
Dan, did anyone get back to you on the procedure to change A drum ?
Old Sep 15, 2010 | 01:31 PM
Dan R's Avatar
Alex,
No, they did not.
Dan
Forcedair1
Sep 8, 2025 01:57 PM
Rlover
Mar 30, 2016 10:04 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
Wes Steenrod
Sep 6, 2015 06:52 PM
SouthernGypsy
Sep 3, 2015 10:54 AM
