XJ40 ( XJ81 ) 1986 - 1994
1988 xj6? or..? brake problems!
Old Oct 7, 2008 | 08:55 AM
fritterfran's Avatar
Default RE: 1988 xj6? or..? brake problems!
The brake lines probably need to be blead. Start in this following order: Right Rear, Left Rrear, Front Right, Front Left.
While you're down there, check for leakage from the calipers. Often, the seals go with age. I am in the process of replacing the rear calipers because my RR has seized. I also need to bleed the brakes because the car pulls to the left upon braking, indicative of potentially air in the lines. Spongy brakes usually means air in the lines. If your problem persists, it could be the master cylinder.
Hope this helps.
Old Oct 8, 2008 | 01:11 PM
Frankie's Avatar
The "88 XJ40 has the power assist which is hydrolic..mineral oil. Check the resevoir to see if it has enough fluid.
jdzubas
Oct 4, 2015 09:14 AM
laserguy
Sep 3, 2015 02:02 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
