XJ40 ( XJ81 ) 1986 - 1994
1989 XJ6 replacing Inner Handle.
Old Apr 23, 2012 | 01:16 PM
Yaoi-Wiccan's Avatar
Default 1989 XJ6 replacing Inner Handle.
My jaguar has broken outdoor handles too but now I want to replace my driver indoor handle. I have a new handle but it did not come with a string on it. Is it possible to take the string off the old one and put it on the new one? Thanks
Old Apr 23, 2012 | 02:25 PM
Evidently yes, as the one you received did not have the cable attached.
Your outdoor handles are a bit more of a problem, because the pot metal tang breaks off.
However with a bit of ingenuity you can remove the fixing pivot rivet and swap right to left. (The moving bit). But you will then need to have a method of replacing the pivot rivet.
Smooth shanked bolt + bearing washers seem to work, with a small lock nut. To prevent things tightening up.
Hardly a Jaguar solution, In know, more Heath Robinson, but I don't have the tool for making a pivot rivet.
Sadly I no longer have that car so can't take a pic.
Remove the door handle and look at it, you will hopefully see what I mean.
Old May 6, 2012 | 09:15 AM
Brill's Avatar
Outer door handles are available through Vintage Jag Works.
They are about half the cost of standard replacement handles and have been redesigned to help eliminate the problem of the broken pot metal innards.
Other Parts
First one was about a 2 hour install, second one in less than half that time.
Talk soon,
JarodL
Mar 7, 2024 01:39 AM
Sprayall
Sep 3, 2015 07:49 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
