XJ40 ( XJ81 ) 1986 - 1994
1993 xj6 starting issue -FIXED
Old Jun 3, 2012 | 06:04 PM
Bert1007's Avatar
Default 1993 xj6 starting issue -FIXED
Hello all. My 93 xj6 is not starting, I feel the best way to go about this is just give a list in chronological order off what happened and how I attempted to troubleshoot. First off I put 20$ of fuel in and it took a while to register and then the gauge fluctuated while driving, which is strange and never happened before. The next morning it cranks with full power and doesn't start.
I checked all related fuses to the fuel pump, all we're fine.
Heard no hissing from the pump
Jumped the relay and still no hissing
Checked the power lead to the pump. NO POWER
Applied direct power from battery to pump, still no hiss.
VCM isn't saying anything.
With this being said, I know my fuel pump is bad since there's no sound from it with direct power. However I still can't figure out why there is no power going to the pump. I just replaced the cap rotor and coil so I know it's not a spark issue. Could there be an unforeseen variable that is stopping power from going to the pump. This isn't the first fuel pump issue I've had to troubleshoot but I'm kinda at a loss here. If any of you seasoned jag veterans could provide some input I would really appreciate it. Thanks for reading. Bert
Old Jun 3, 2012 | 08:13 PM
Lumppy47's Avatar
The pump is most likely toast, Have you checked the relay it might also be bad. It directs power to the pump. If youre doing the work yourself get an airtex pump(its a walbro the same as that is inside the canister).I was short of time when i did mine so i removed the back seay ,cut a hole in the shelf above the tank and took every thing out without removing the tank (took about two hours). When putting back together reseal the hole piece with a couple of tabs screwed into the shelf then seal it up with rtv.
Old Jun 3, 2012 | 10:29 PM
Bert1007's Avatar
Yea I'm certain the pump must be replaced. But I'm still confused as to why there's no power going to the pump. Is there some type of fail safe that kills power when the pumps failing?
Old Jun 4, 2012 | 08:01 PM
Lumppy47's Avatar
There is a relay,I believe it in the trunk,left side by the tail light under the carpet covered inner side panel.I think its the blue one. I would recomend getting a hanes manuel as it has all the diagrams and fuse and relay locations.
Old Jun 4, 2012 | 10:25 PM
robhair's Avatar
the relay is in the trunk RIGHT side blue hella relay pull one from the engine and try replacing it. there is a shutoff switch in case you're hit hard in the front end. It's located in the far left corner drivers side where your left foot would be it can be flipped if you hit it just right with your toes or cleaning with a vacuum hose
Old Jun 7, 2012 | 06:41 PM
Jaggier's Avatar
Any news? I have a 94 VDP with exact same issue. When I tried to jump the pump off the blue wire to the pos side of battery it sparked like crazy.?
Did you get it fixed?
Old Jun 12, 2012 | 09:14 PM
Bert1007's Avatar
This has turned into a bit of a nightmare for me. I brought it to the shop, had no time to continue myself since I work five days a week. They replaced the fuse in the right side panel, number three, I believe and it started, ran and drove for about an hour. Went to start it again a while later and it wouldn't kick over. They thought the pump wasn't sending the correct pressure. Got the correct pump, replaced, then come to find out the injectors aren't spitting fuel into the cylinders. They had a specialty electrical guy come investigate and he said it was the CPS. crank position sensor, and that was the root of the problem. It wasn't. It's still at the shop and the can of worms has been opened. It's been in the shop for over a week and I'm at a loss.
Old Jun 12, 2012 | 11:38 PM
rolexmike's Avatar
Aw man,
Sorry about your big cats problems Bert1007, i know when my 94 VDP's A/C was not working last year at this time i had 5 different repair people telling me each a different thing. May i ask how much they charged you to replace the pump? Please keep us posted!
Old Jun 14, 2012 | 01:50 PM
Jaggier's Avatar
I finally pulled the trigger and pulled my fuel pump. Totally rusted and pump is shot. Replaced and put everything back. Got the engine to finally start to sputter. Some signs of life. Still wont start. Plugs sook like they are fouling. Too much gas. Trying to find a repair shop to clean the injectors.
Let us know what happens next as I may have to change the CPS on mine.
Old Jun 14, 2012 | 02:42 PM
I think that there is more than one issue here.
@Jaggier, you would be better to start your own thread, with all symptoms, for better answers.
@Bert, a dying link lead, caused all of the problems you describe on my 92.
When finally pulled, it was fried.
Old Jun 14, 2012 | 03:28 PM
Bert1007's Avatar
It was a fuel line blockage the whole time. Car is running great. I think the mechanics at my shop were reading into the problem a little too much. But all is said and done, I got anew CPS, fuel pump, pressure regulator, and battery for 590$. I believe the price for the pump and labor to install was 220. I work for the company that owns the shop so that's my employee price. Anywhere else, I wouldn't be surprised if it was a 2000 dollar job. I'm just glad to have my baby back!!! Thank you for all your input. I appreciate it!
Old Jun 15, 2012 | 03:53 AM
Cadillac's Avatar
Good news, it's all fixed then
Old Jun 19, 2012 | 10:59 PM
Sids-Jag's Avatar
When you say fuel line blockage, did you replace the lines going from the tank to the injectors? Im having the same problem with my XJ-6
Old Jun 19, 2012 | 11:02 PM
Sids-Jag's Avatar
As a added note my pump runs. When I start the car it will idle for about 15 seconds and then dies.
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Drew2006
Nov 24, 2015 11:14 AM
tberg
Sep 7, 2015 07:32 AM
1964Daimler
Sep 2, 2015 11:41 PM
