XJ40 ( XJ81 ) 1986 - 1994
1994 Jagaur XJ6 Key wont turn in ignition
Old Feb 15, 2010 | 04:12 PM
Kevoniua's Avatar
Default 1994 Jagaur XJ6 Key wont turn in ignition
Hello everyone Im new to these forums of course, I just bought this Jag (94 XJ6), and I went move it from the driveway this morning, it started fine, the wheel was kinda hard to turn, so I took it out of reverse then to park, about a minute later I got back it to start it again and the key would not turn to crank. The odometer is reading jumbled characters and the radio clock is flashing. I know you guys can help me... I hardly have any idea what it could be other than ignition coil. Please help, I will return the favor when I can.
Old Feb 16, 2010 | 08:19 AM
Fraser Mitchell's Avatar
If the ignition key will not turn after you have inserted it into the switch, try waggling the steering wheel a bit whilst trying to turn the key. This is because there is a steering locking pin that is released by the key, and it can stick a bit when you first try to turn the key. If it is not this, please describe symptoms more fully.
Old Feb 19, 2010 | 06:31 PM
Kevoniua's Avatar
Thanks worked perfectly...
philwarner
Oct 4, 2024 01:37 PM
Wolfy
May 28, 2024 08:06 AM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
