88 xj6 replace blinker/hazard flasher module w/separate flashers?
i keep having to solder the circuit board in the modules and im not sure if im going to be able to keep doing it for much longer. are there any alternatives? maybe rewire it from the switch on the column and replace the module with separate flasher units? how difficult would that be? or is it even possible? thanks
I would be more inclined to find a second hand module from a wreck and see how that goes. I'd try and avoid rewiring the entire circuit from the indicator stalk all the way through the various components.
That's my 2 cents worth...
i have lots of time and i wouldnt mind trying as im getting tired of getting pulled over for having no blinker or intermittent tail/brake lights.. and i might as well convert that too since its basically half GM already. you know of anyone that has done this or even attempted it? just trying to find some ideas on how to go about this..
Tony K
Mar 26, 2024 01:53 PM
hafren
Aug 30, 2023 03:42 PM
rusty37
Jun 7, 2016 04:43 PM
