XJ40 ( XJ81 ) 1986 - 1994
91 Jaguar very sluggish
Old Jan 18, 2014 | 06:11 PM
buymeaboat's Avatar
Default 91 Jaguar very sluggish
This morning, I became the owner of a 91 Jaguar that has been sitting for six years. She was kept running but not really driven. It has 71k miles. Have owned more Triumphs than I can count but my first Jaguar and its issues. OK, here is the issue. The car had 1/8th of a tank of fuel which I suspect was or had gone bad. The car ran so I added another two gallons of fuel and fuel injector cleaner to get it to run smoothly. No problem, that worked. Then when I took it out to drive, she had no power. I could get rpms out of the engine by pushing on the throttle on the engine, but under load she was just not going. She would limp down the road, but that was it. I have my ideas, but want to get an idea from those who have been working on these as I would like to incorporate Jaguars into my projects. Mike in Ocala Fl
Old Jan 18, 2014 | 06:39 PM
Welcome to the forum Mike,
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 18, 2014 | 07:05 PM
MidwestJag's Avatar
Hi Mike:
Welcome to Jaguar and welcome to the forum! Sounds like an exciting project. I also have a 91, which really is a pride and joy. I wish you all the best.
Sounds to my mechanically-ignorant ears to do with a dirty throttle body. But, I'm wondering if you have any codes on the VCM. First, is the Check Engine Light on? Second, after you've turned off the car, re-turn the key to position II (without cranking) and press the VCM button. Note what appears on the display and report back. It will help in tracking down possible faults.
Best,
Scott
JarodL
Mar 7, 2024 01:39 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
