XJ40 ( XJ81 ) 1986 - 1994
Air Conditioning Fan
Old Jul 4, 2008 | 06:11 PM
Big E's Avatar
Default Air Conditioning Fan
I have an '88 Vanden Plas and believe that my air conditioning problem stems froman inoperativefan. This is the fan that is to the left directly behind the grill. Should the fan run constant?
Old Jul 4, 2008 | 11:08 PM
Thermo's Avatar
Veteran: Navy
Default RE: Air Conditioning Fan
No, the fan should not run constantly. When you set the fan to off, it should turn off. If it is remaining on, then you most likely have a bad relay or a bad dash switch. It should turn off when the setting switch is set to OFF.
Chris "thermo" Coleman
Old Jul 5, 2008 | 08:27 AM
badmojo's Avatar
Are you saying that the fan runs constantly or that it doesn't run at all? My 95 used to blow fan fuses sometimes when it got really hot outside and it ran alot. Replacing the fuse would usually take care of the problem.
mbergen
Oct 23, 2019 10:26 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
SCMike
Sep 9, 2015 09:30 AM
1100me
Sep 7, 2015 06:26 AM
