XJ40 ( XJ81 ) 1986 - 1994
Ariel Antenna Questions
Old Mar 24, 2024 | 08:37 AM
dakico968's Avatar
Default Ariel Antenna Questions
I have spent a day looking thru the site so I would not have to post a new thread. I've been working diligently on my new2me 1994 XJ6/XJ40 and I am rather thrilled to say, it's going rather swimmingly! My newest project is the radio, I've noticed that while I can get one channel to come in, the rest of the frequencies are static, due to my ariel antenna appearing to be dead. I've checked the relay and all the 4 wire contacts have power except for the blue wire. This could totally be operator error, as I am not mechanically inclined in any way shape or form, but i enjoy the challenge. Again, I digress....I have checked all 3 fuse boxes, and found non related to the ariel antenna. I've also swapped the relay for another just to see if something would happen. At one point I thought I heard the motor while I was inside the cab but no movement. Just looking for some ideas. Again, my sincerest apologies for posting this as I am sure the answer is inside the site somewhere. I just had not seen anyone getting radio signal, and no ariel movement.
Old Mar 24, 2024 | 11:03 AM
Lawrence's Avatar
If the antenna motor is running, it usually means that the plastic gear "tail" attached to the antenna mast has a broken tooth or two. Your antenna (1994 ) should be a Harada brand. Earlier antennas as made by Hirschmann.
A new mast assembly with gear tail is available on eBay etc, but you will have to remove the old broken mast and section from the case first.
Re-check that you can actually hear the motor running before doing anything.
Best to get a friend to turn on radio while you listen in the trunk.
Old Mar 24, 2024 | 11:39 AM
dakico968's Avatar
Will do thank you for the input I'll try that this evening
1990XJ40
XJ40 ( XJ81 )
Nov 11, 2022 11:16 AM
mikega
May 24, 2021 05:32 PM
shaune
Jan 29, 2016 08:44 AM
jagfan47
Jan 11, 2014 06:57 PM
gjagone
Dec 4, 2008 03:39 PM
