XJ40 ( XJ81 ) 1986 - 1994
brake system please help!!!!
Old May 21, 2008 | 09:00 AM
XJ6_1994_J40's Avatar
Default brake system please help!!!!
Replaced the two front rotors and pads to my 94 xj6, ever sense I now gte the abs light and brake light staying on which keeps the brake pedle up. it's like driving without power brakes. the all of a sudden evrything is back to normal, brake is fine and wornking, then again while driving back on comes the abs and brake light and this continues evryday. Does anyone have an idea. I have bleed the brake line what else could it be????? by the way sometimes I hear under the seering colum (dash) a relay that clicks contant, is that were the abs relay switch is located , maybe it's bad. please help....
Old May 21, 2008 | 08:49 PM
ibjags's Avatar
Default RE: brake system please help!!!!
i think the abs relay is in the trunk
driver side
common fault is the relay power terminal solder point becomes loose from circuit board in the relay
i"ll check to verify location of relay
Old May 21, 2008 | 09:04 PM
ibjags's Avatar
i"ll have to look it up tomorrow from work
diagrams not listed online thru jaguar
Old May 21, 2008 | 10:16 PM
JagtechOhio's Avatar
The ABS relay is under the dash, left side, mounted on a bracket on the LH blower motor. Turn the key on, don't start the engine, you should hear the brake pump run for maybe 20 seconds and then shut off when the "Brake" and "ABS"lights go out. There is a pressure switch on the accumulator housing that tells the pump when to come on. You likely have a problem with the pressure switch, or the pump itself is intermittantly failing.
Old May 22, 2008 | 11:55 AM
Thanks for giving me a head start of were to look, I will work on this this comming weekend and update.
Old May 22, 2008 | 12:34 PM
You're welcome. If the pump isn't running, test it for power supply. These pumps are very reliable, but I have seen one fail. Contact me privately if you need a good used one.
clubairth1
30
Sep 3, 2025 04:38 PM
mbergen
Oct 23, 2019 10:26 PM
jdzubas
Oct 4, 2015 09:14 AM
Jefro
Sep 15, 2015 01:44 PM
