XJ40 ( XJ81 ) 1986 - 1994
Brakes
Old Jun 30, 2019 | 06:39 AM
iowabobg's Avatar
Default Brakes
I have an 88 XJ6. Brake pedal goes to floor. I have replaced master cylinder and a faulty abs relay.. Brake pedal still goes to floor. It appears I'm no getting power tot he brake pump. Any advice?
Old Jun 30, 2019 | 08:11 AM
jerry_hoback's Avatar
There are way better people to reply than me, but- Sounds like a severe lack of brake fluid. Has the system been checked for leaks? Has it been bled lately? and... are you sure the m/c pushrod was reattached.... Hope its an easy fix!
Old Jun 30, 2019 | 11:26 AM
Don B's Avatar
Hi iowabobg,
The natural first question is whether you bench-bled the new master cylinder prior to installing it and then properly bled all the air out of the brake lines. If I recall correctly, Jaguar recommends first bleeding the right rear caliper, then the left rear, right front, and left front. If the master cylinder was not bench bled, you may have air trapped in the M/C that will not make its way out of the system by bleeding via the caliper bleed screws.
For diagnostics of your power hydraulic system, see the manual I am attaching below.
Please keep us informed.
Cheers,
Don
scottw
Feb 4, 2025 07:33 PM
mikchek
May 8, 2019 11:38 AM
malx
Nov 27, 2015 06:27 AM
alabbasi
Nov 21, 2013 10:40 PM
jimlombardi
Nov 6, 2012 11:30 AM
