XJ40 ( XJ81 ) 1986 - 1994
Carpets!
Old Sep 19, 2012 | 12:24 PM
Fixer88's Avatar
Default Carpets!
Do you guys know anywhere to score a new carpet set to fit an 88 XJ40? Ive been hunting around online a little bit, and most of what I find is for the series III over in EU. thanks!
Old Sep 19, 2012 | 02:52 PM
MidwestJag's Avatar
I would look for a good used set either on ebay or at a scrapyard. You might want to also try one of the parts suppliers, as many of them have vehicles for parts from which they harvest.
Scott
Old Sep 19, 2012 | 02:58 PM
Fixer88's Avatar
thats what I was afraid of... the chances of finding good used carpets is probably slim to none, so it looks like a custom set must be made
Old Sep 19, 2012 | 05:21 PM
MidwestJag's Avatar
You know, the thing is, I think it might not be as hard to find what you are looking for as you might think. I would do some serious digging and calling around - even across the country - before I purchased something new or custom. You could potentially save hundreds; and since these cars aren't exactly getting newer, more and more of them are eventually going to be hitting the back forty for parts...
Just my thoughts!
Scott
Old Sep 20, 2012 | 08:24 AM
Rob Evenson's Avatar
Default Carpets
Hi,
Glad you found part of your problem with the soft brakes on your other post. In regard to carpets, go to this site (no affiliation) and check it out. For me, I don't think the prices are that bad considering they are new and complete carpet kits:
World Upholstery & Trim: Jaguar XJ Series [1968 - 2010]
Good luck
Rob Evenson
Old Sep 20, 2012 | 04:31 PM
Fixer88's Avatar
Originally Posted by Rob Evenson
Hi,
Good luck
Rob Evenson
Ill check the site! the suspension still is an issue, but I believe Ill be installing a new non SLS suspension package in the next week or two. once thats done, ill be moving ti the climate control, which is a strange problem. the blowers work for the heater, which is quite warm but.... when I hit the AC, it wont blow out of the vents (although I can hear the blower motor working.) I figure it must have something to do with the vent actuators, but one thing at a time with this project! thanks for the reference to carpets, I find it very difficult to see finding Like new carpets in a used 25 y.o. vehicle, but who knows
Old Sep 20, 2012 | 09:21 PM
Default carpets
Hi,
Go ahead a start your post for the AC/blower issue. It could be one of several things causing your problem. Do all of the settings (low, med and high) produce air flow? The climate control unit may be the issue.
Rob Evenson
bdboyle
Sep 16, 2019 05:58 PM
PinnacleWax
Detailing / Car care
Sep 25, 2015 12:46 PM
Nigels420G
Mark V - X 420G
Sep 25, 2015 10:10 AM
PinnacleWax
Sep 16, 2015 10:28 AM
