XJ40 ( XJ81 ) 1986 - 1994
Clunk on Passenger Side Over Bumps. Shock Bushing?
Old Oct 27, 2013 | 06:17 PM
NTL1991's Avatar
Default Clunk on Passenger Side Over Bumps. Shock Bushing?
I've had a bit of a clunking noise on the passenger side of the car when going over bumps or deep expansion joints in the road. Usually only at higher speeds. I thought the sound was coming from the passenger side rear of the car.
I checked the front suspension when I did some maintenance, and I saw the upper front shock bumper is toast. It was so bad that the bellows had fallen down to the bottom of the shock. The driver's side looks okay.
How are these to change? Would this give a clunking over bumps? Would bushings also cause this?
Thanks,
Nick
Attached Thumbnails Clunk on Passenger Side Over Bumps. Shock Bushing?-img_0827.jpg
Old Oct 27, 2013 | 07:26 PM
jerry_hoback's Avatar
I changed mine this summer. It wasnt bad at all using a spring compressor of course. Go for it.
Old Oct 28, 2013 | 11:32 AM
mrtalkradio's Avatar
Yes, it would cause that sound. Those rubber bushings need replacing, they are also under the hood where the bolts attach.
As Jerry posted above, with a spring compressor it's not bad. Using strength, requires a lot of strength, and you have to be quick. If you can compress that with one hand and put the bushings on with the other? You should play in the NFL.
02jagstype
23
Oct 23, 2022 07:03 PM
kevinl
Oct 31, 2019 06:15 PM
Dicque
Sep 19, 2015 12:53 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
