XJ40 ( XJ81 ) 1986 - 1994
Dimmer switch bypass?
Old Apr 11, 2015 | 12:02 PM
dtrain's Avatar
Default Dimmer switch bypass?
92 sovereign
Gauge cluster lights are on all the time. Traced the problem to the dimmer switch. Trying to locate one but wondered if I could bypass it altogether? I don't use the dimmer itself - just need the gauge lights off when I turn the car off (which is not the case right now). I don't even mind if they are on when the car is on whether day/night. Any thoughts or suggestions would be appreciated.
Old Apr 11, 2015 | 06:39 PM
Don B's Avatar
Originally Posted by dtrain
92 sovereign
Hi dtrain,
The dimmer module is mounted in the steel frame on the steering column. I don't have any photos of the front of the module, which is an aluminum heat sink extrusion, but the photo album below shows how to disconnect the module's three tabs from outside the steel frame:
Welcome to Jag-lovers - Members Photo Viewing Page
This album shows how to tip the module to get the potentiometer shaft to back out of the frame:
http://www.jag-lovers.org/snaps/snap...?id=1389923645
And this album shows what the electrical connectors look like:
The Jaguar Daimler Heritage Trust Supplementary Model Information DVD contains the Electrical Guides for the XJ40s, which would help you determine which wires to jump. Unfortunately I'm not aware of an online pdf of the guides:
Jaguar Heritage. XJ40 (XJ6 & XJ12) SUPPLEMENTARY MODEL & SERVICE INFORMATION JHM 1130
P.S. I have seen salvaged dimmer modules offered on eBay. Just be sure the electrical connector matches yours.
Cheers,
Don
Old Apr 11, 2015 | 08:48 PM
dtrain's Avatar
Default dimmer switch
Thanks for the reply Don,
I have attached the switch that I have. No luck with this one yet on ebay - several available with different connectors as you pointed out. Checked the wiring diagram on the Haynes manual that I have but didn't see this. Maybe I missed it or it's available elsewhere but I haven't had any luck just yet.
Any chance there is a common problem with a dimmer switch gone bad that might point me in the right direction to fix the one that I have?
File Type: pdf
Old Jun 17, 2015 | 08:03 PM
dtrain's Avatar
Finally found the right dimmer switch. Replaced and still have the same problem. Should I be looking at a relay, module or short somewhere? Anyone have thoughts on what do to next?
Thanks.
hoodun
Nov 20, 2022 02:35 PM
Darrenmb
Sep 27, 2015 08:43 AM
reb1999
Sep 26, 2015 08:41 AM
kevinl
Sep 24, 2015 08:25 PM
