XJ40 ( XJ81 ) 1986 - 1994
Elec windows
Old Jul 30, 2009 | 08:39 AM
Jimbo's Avatar
Default Elec windows
Can anyone help, my right hand side front and rear electric windows have stopped working.
Replaced the 30amp fuse in the R.H. drivers footwell, alas to no avail.
There was no warning, they were working fine, then just ceased to operate.
Jim
Old Jul 30, 2009 | 08:58 AM
93xj6's Avatar
Did the 30amp fuse blow? And then did that occur again when you replaced it? Try taking off the door panaling and making sure all the wires are connected right, maybe something got disconnected. I don't know if you have the hanes booklet, that shows how to take off the paneling...otherwise I'm sure you can find instructions somewhere on the web. I bet Jag Lovers has a page on that
Old Jul 30, 2009 | 12:27 PM
just a quick reply but what Car have you got because one 30 AMP fuse per side not only seems odd but asking for a fire. My XJ40 has two separate 15 amp fuses per side ie;4 in total although it is a 92 so things may have changed since.
Old Jul 31, 2009 | 02:25 AM
Jimbo's Avatar
Default !994 xj40
Thanks for the replies fellas.
It is a Jan 94 with the battery in the boot.
On the inside of the fuse cover it states the 30a is fo RH side front and rear elec windows. The fuse I removed wasn't blown and the replacement didn't operate windows either. I have a Haynes manual in the boot but boot link rod has popped off so cannot get into boot until the weekend.
My mate replaced the lock barrel and forgot to check rod before closing boot, Double Whammy!
Old Sep 26, 2009 | 05:20 AM
Jimbo's Avatar
Default Sorted
Jim
It was a faulty wire!
Old Oct 1, 2009 | 05:28 PM
in2town's Avatar
Default where was the faulty wire
on my car, all the windows work but the window will not work from the front passenger side, the driver can operate the window but the passenger cannot, any ideas anyone
Old Oct 2, 2009 | 02:30 AM
Jimbo's Avatar
Default In-op windows
The faulty wire was one than went to master switch, didn't do repair myself so don't know which one. There is a PCB board inside master switch don't know about passenger side switch. Mine is a 94 XJ40 sport it has a 30a fuse each side which protects the switches in front doors, suggest check them first. There are plenty of switches on e-bay, UK sellers send international if need.
Good luck.
philwarner
28
Jul 11, 2017 10:21 AM
NS2000XKR
Jan 1, 2017 10:41 AM
blackenedindustries
Sep 30, 2015 10:17 AM
apolloxk8
Sep 28, 2015 08:27 PM
