XJ40 ( XJ81 ) 1986 - 1994
Electrical issue
Old Dec 26, 2021 | 12:21 PM
Paul B.'s Avatar
Default Electrical issue
1993 XJ6 Vanden Plas . Car runs well and on occasion will die without warning. When I pull the "Fuse Failure Link" fuse located on the left side (drivers side for U.S.), fuse location is A3 with a 3 amp fuse and reinstall it, the car restarts with no problem. The fuse is not blown. Just pulling it and reinstalling it takes care of whatever is being "reset".
Old Dec 26, 2021 | 02:35 PM
Lawrence's Avatar
What does the VCM fail code show before the reset?
Larry
Old Dec 26, 2021 | 02:47 PM
Paul B.'s Avatar
Larry,
It's showing "Fuel Fail 44"
Old Dec 26, 2021 | 03:19 PM
Paul B.'s Avatar
Should I replace the O2 sensor?
Old Dec 26, 2021 | 04:26 PM
Parker 7's Avatar
[xj40] Fuel Fail 44 - XJ40 - Jag-lovers Forums
A quick and cheap and easy thing you can try is to jumper the fuel pu.mp relay between socket 30 and 87
The pump will run at all times with the keys in your pocket so plan accordingly
preferred to use blade type connectors in the fuel pump relay socket
The auto parts store can help you make a jumper with the behind the counter tool kit and heavy wire
Old Dec 26, 2021 | 04:39 PM
Paul B.'s Avatar
Thank you!
Old Dec 26, 2021 | 04:46 PM
Parker 7's Avatar
Edited above post for more info
Old Dec 26, 2021 | 11:34 PM
Lawrence's Avatar
FF44 circuit failure will not prevent engine running, it will just keep the car in open loop operation, so you'll have less power, run rich/use more gas.
Check for a vacuum leak or bad connections before assuming O2 sensor has failed.
Using a meter there is a test to determine the condition of the oxygen sensor, search the forum for details.
Larry
Old Dec 27, 2021 | 12:03 AM
Parker 7's Avatar
See page 91 of the 1991 wiring guide file below
File link below
Jaguar XJ40 Electrical Guide 1991
A note on the O 2 sensors which play a major role in the closed loop mode of the ECU
Is how it gets from the open loop on cold engine start to close loop triggered by the coolant temp sensor using the O2 sensors for a just right fuel mixture
This trigger point is 88 C for the later refined AJ16 engine from your AJ6 engine so yours is probably the same value
Some things that can keep the ECU from seeing the 88 C is a dirty temp senspr connector, temp sensor itself ,or the actual coolant temp never gets to 88 C , coolant thermostat failed open
The temp gauge on the instrument cluster is a separate temp sensor not related the the one triggering you ECU open / close loop
Your instrument cluster is on page 31
Verifying
True , the instrument temp sensor ( transmitter ) is single wire and the ECU temp sensor is 2 wire so they are separate
But it can be used as a reference to know where your coolant temp is at
Donel editing
Old Dec 27, 2021 | 12:43 AM
Parker 7's Avatar
See page 181 and 183 of the Jaguar 801s PDF below
This document is in 3 sections : the later AJ16 . your AJ6 , and the V12
801S TITLE (jagrepair.com)
You can compare the temp sensor with a meter against the chart
Old Dec 27, 2021 | 03:37 AM
Welcome to the forums Paul,
That's a very strange thread title. Did you intend to post in an existing thread? If so you must have clipped some of the string because it doesn't find a thread.
Old Dec 27, 2021 | 06:01 AM
Paul B.'s Avatar
I copied and pasted it from another thread that I miss posted to the wrong model group thread and that's how it "pasted". It was originally posted as just "Electrical issue". I couldn't find anywhere that I could've edited the title.
Old Dec 27, 2021 | 06:04 AM
Paul B.'s Avatar
Will do.
Thank you.
Paul B.
Dec 28, 2021 02:45 PM
Chris Brindle
Jul 6, 2021 01:07 PM
Jaesteban
Feb 10, 2020 09:00 AM
kesslari
Sep 25, 2016 11:49 AM
mrtalkradio
XJ40 ( XJ81 )
Feb 24, 2012 05:36 PM
