XJ40 ( XJ81 ) 1986 - 1994
Eng cuts out at steady speed under light throtle
Old Jul 29, 2011 | 05:55 AM
Leedsman's Avatar
Just a thought -- I assume you torqued down the head nuts radially starting from centre and working outwards. Have you re-torqued now the engine's warmed up/cooled down a few times? Otherwise the usual stuff...
Leedsman.
Old Jul 29, 2011 | 08:07 PM
Lumppy47's Avatar
As you had head gasket problems with #5 & 6 you might have a plugged up catalitic converter (the ones that are in the manifolds plug up then forces the ehaust back up the manifold which creates heat and slugish engine responce). I had similar problems and resurfaced head twice before finding the problem was caused by the cats (i just punched the guts out of them and put them back and the emissions still checked out ok I guess the ones in the pipes worked). The best way to check is put the car on a lift remove the manifolds from the exhaust pipes,start it up and see if there is equal flow out of the manifolds.
toronadomike
Jan 22, 2026 10:13 PM
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
