XJ40 ( XJ81 ) 1986 - 1994
Heater controls
Old Aug 8, 2010 | 07:46 AM
Jimbo's Avatar
Default Heater controls
My aircon has expired, requires new pump. Since then I cannot control air flow temp in car. Blows warm air when switch is in cold position. Is this a switch problem or the fact that aircon isn't working?
Jimbo
Old Aug 8, 2010 | 06:08 PM
Hi, I don't know what year car you have but if you look in the FAQ you will find an outline of the AC/heater controls.
Basically if you select 'Man' or 'Manual' the car should behave like any car without aircon.
In nearly 8 years with my 92 I have just about never used the aircon and always use 'Manual' to draw air from the outside.
Of course you also need to set the heat control to cold air, otherwise it will be warm, just like any other non aircon car.
Old Aug 9, 2010 | 02:32 AM
Jimbo's Avatar
http://http://cgi.ebay.co.uk/ws/eBay...=STRK:MEWAX:IT
Thanks for the quick reply, it is a 94 XJ40 Sport. I have attached a link showing type of panel. Do you know if clock can be replaced or is it part of panel?
JIm
Old Aug 10, 2010 | 02:20 AM
Jimbo's Avatar
Tried your solution, airflow is very low even on high setting. Also drove in this morning and selected hot using manual mode and temp of air was still cool after a 20 mile drive. Thinking it might be the temp switch playing up! Could airflow be restricted by blocked air intake?
again
Jimbo
Old Aug 10, 2010 | 02:48 AM
This is a reccuring type of problem. Sounds like one of your blowers might not be working properly.
To save typing, why not have a read of this thread and then see how you get on.
https://www.jaguarforums.com/forum/s...heater+blowers
It will give you an insight into how the thing works etc.
Old Aug 11, 2010 | 02:50 AM
Jimbo's Avatar
Default Heater Controls
Thanks Richard, very helpfull.
Old Aug 19, 2010 | 12:01 AM
Jimbo's Avatar
Hi Richard,
Would you be able to help me with an owners manual diagram, I have a haynes manual which covers XJ40 to 94, but alas when it comes to heater blower removal it shows a model with a glovebox and mine doesn't have one. Spoken to an ex UK jag mechanic, now retired, who tells me the RH blower is under steering wheel on RH side of car, not under left footwell as earlier models seem to have sited. Comments appreciated.
Jimbo
Old Aug 20, 2010 | 11:28 AM
I have just seen this, sorry.
You have 2 blowers one on the right and one on the left, so your guy is correct.
First off check all the fuses in all 3 fuse boxes, before ripping out the blower.
Old Aug 21, 2010 | 08:35 AM
Jimbo's Avatar
Already checked the 3 fuses, all OK. Seems I will have to live with it as the Jag guy reckons a good half a day if in a serene mood, otherwise a day to replace and all relays appear to be inside blower. Last hope is that the fuse panel may have lost a solder joint so I am going to get an auto electrician to check wires to blower. Do you have any info on removal of RH blower in a RHD car?
ATB
Jimbo
bdboyle
Sep 16, 2019 05:58 PM
ryan_border
Dec 23, 2015 04:27 PM
zdrapec
Sep 25, 2015 05:49 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
texaspete
Sep 10, 2015 08:34 AM
