XJ40 ( XJ81 ) 1986 - 1994
How much would this be worth?
Old Feb 20, 2008 | 04:10 PM
ken@britishparts.com's Avatar
Default RE: How much would this be worth?
You won't make money on it, so don't look at as an investment. Not running, I would make $1000 my very highest end. I really wouldn't want to pay even half that. Lot's of unknowns that could cost you big down the line. Remember, it's the seller's problem. If you buy it, they are your problems. At this point you know nothing about tranny, brakes, suspension problems, a/c, electrical, etc. It's a big risk.
Old Feb 20, 2008 | 06:22 PM
jag_genius's Avatar
expensive car to learn on.. lol
Old Feb 20, 2008 | 06:36 PM
jag_genius's Avatar
i quess if all your looking for is just pulling in to class in a jag..
Old Feb 20, 2008 | 06:59 PM
jag_genius's Avatar
makes sense
Old Feb 21, 2008 | 08:37 AM
Sounds like you are in the right place. I thought you intended to just do a head job and ride off into the sunset. Sounds like you're looking at this realistically. Expensive items: ABS pumps, a/c problems, rear hub carrier, diff. Check all exterior door handles! The engine and trans are fairly solid on these. They did like to throw head gaskets, but that's usually not too bad. It would probably make a fun toy as a second car. Besides the items above, real expense will come in cosmetics. Interiors and chrome are expensive!
Old Feb 22, 2008 | 11:02 AM
Cadillac's Avatar
You sum up quite well . That's one of the main reasons I was looking for a '93-94 XJ40 not earlier model years . My personal thought is that once you get in a Jaguar ,you always wanna have one in your garage
Old Mar 17, 2008 | 02:10 PM
XJ40ish's Avatar
Do yourself a favor and stay away from this one. What can I say to a newly minted enthusiast? I own a pretty good, mechanically sound 93 XJ40 and it recently required a relatively minor repair due to a failed transmission mount. Now understand that Jaguars are built so complexly by gnomes in a secret location sothat a simple transmission mount requires about 16 pieces ie:numerous springs washers plates, Etc, and this small item atributed to a small slight vibration was over $1000.00 to repair. Add in a set of rear wheel and axel bearingsat $600.00 and you're only starting to get the picture. Thesecars sell very low used for good reason, not that they're all bad, but they are very, very ( note here )very expensive to maintain and keep running. Stay away from any engine work as these engines are build with the precission of a swiss watch and any even minor problems are huge dollars to fix. In the end you will spend thousands in small repairs and more in parts only toend up with a car that's worth at best a thousanddollars or so. If you must venture into things Jaguar, loook at the XJ40 in and around 1993 - 1994 when they were mostly reliable and trouble free although still darn expensive to run. The last years for the XJ 40 were the best. Get one that runs, and runs well.
Old Apr 8, 2008 | 12:49 PM
Wow! That's a project!
