XJ40 ( XJ81 ) 1986 - 1994
idle rises and drops after cold start
Old Oct 2, 2013 | 06:29 PM
jagnoob's Avatar
so the rpms are supposed to be high at first and then bleed off? kind of like a choke or fast idle that doesnt last very long?
Old Oct 2, 2013 | 07:22 PM
AllanG's Avatar
Yes it's quite normal for a cold start. The tach should be at about 1000rpm for a few seconds then it will slowly reduce down to normal idle speed.
If you have disconnected then reconnected the battery, when you restart the car it will probably idle much higher (1200-1500rpm) for a few seconds and then begin to come down. This is because any stored position values will have been erased from the ECU's RAM.
Cheers,
Allan
Old Oct 2, 2013 | 08:24 PM
jagnoob's Avatar
oh ok, i get it now. thank you for your help
99xk8guy
Sep 29, 2025 10:51 PM
JarodL
Mar 7, 2024 01:39 AM
tberg
Sep 7, 2015 07:32 AM
Broken_Spanners
Sep 6, 2015 11:34 AM
Bowman
Sep 3, 2015 03:17 PM
