XJ40 ( XJ81 ) 1986 - 1994
Jaguar wont start
Old Jan 12, 2008 | 05:33 PM
FactoryJaguarTech's Avatar
Default RE: Jaguar wont start
It is hard to see voltage with meter. Ocsilloscope is better, unfortunately not everone has one on hand.
Have you checked fuel pressure? If you have good pressure, then I would suspect the injectors. Perhaps rusted closed due to water? I would perform an injector cleaning prior to replacement. See if the chemical opens them up.
Anyway, first check for fuel pressure and resubmit post if pressure good.
Old Jan 13, 2008 | 01:32 PM
93xj6's Avatar
Sounds kind of like what happened with my car, I would probably replace the injectors.
My car it turned but would not start. But also I had the battery replaced first. But since you were able to start it that one time, the battery should be fine just get some new injectors
Old Jan 13, 2008 | 03:35 PM
Cadillac's Avatar
Turn your key in start position and wait a few secs w/o starting your engine .You should hear some "whirring" noise .If not check your fuel pump or relay .
fast40driver
Apr 19, 2024 07:24 AM
Drew2006
Nov 24, 2015 11:14 AM
jdzubas
Oct 4, 2015 09:14 AM
Fraser Mitchell
Oct 1, 2015 04:06 AM
1964Daimler
Sep 2, 2015 11:41 PM
