XJ40 ( XJ81 ) 1986 - 1994
Low Beams/Bulb Failure
Old Jan 18, 2011 | 07:33 PM
estunum's Avatar
Default Low Beams/Bulb Failure
I have four headlights and the issue I'm having is that the low beams (outer beams) do not work. If I turn on the high beams, all four headlights turn on just fine. I had this problem before, on only one side though, and ended up having to replace the replay module. This time around, I do not know what's the problem.
What I've tried...
I replaced both relay modules
checked fuses. all fine
checked that the filaments in the low beams were intact, as I understand these have two filaments. one for low beam, and one used when high beams are on along with the inner beams. filaments seem intact.
not letting it to chance, I replaced both on the low beam head lamps
new modules, new headlamps and still have the issue.
Am I missing something? Is there something else I can check?
What I've been doing for night driving for now is I disconnect the high inner beams, and simply switch on my high beams. The light output seems to be about the same on that other filament, it's just a little high on the road.
Old Jan 19, 2011 | 04:55 AM
Cadillac's Avatar
There are three relays under the passenger side footwell, just under the glove box there is a cover ,unscrew it and you will those those big main relays . Have them checked out , those might be culprit as well
Keep us updated , hope this helps
Old Jan 20, 2011 | 01:40 AM
estunum's Avatar
You have an idea what they look like? I didn't get a chance to look at them. Reason I stalled a bit is to make sure I know exactly where you are talking about. Is it right underneath the glove box? Where I'd have to remove the the trim? Technically called the under scuttle pad. Or is it below all that, close to where the passenger's feet would lie?
I was going through my parts catalog and couldn't find relays in that area, they aren't really labeled where they come from anyways. Just close ups of the parts. Anyways, reason I asked if you now what they look like is to see if these are it...
Or are you talking about the fuse box? As you can see from the pic below, I compiled the list of parts into a single page. Just the the one before. Same diagram, but the list was put in two pages. There's a diagram for just one fuse box btw, shouldn't there be two? Since there's on on each side? There's is however a diagram for the fuse box in the center console.
Old Jan 20, 2011 | 03:47 AM
Cadillac's Avatar
I had posted a thread about my lights problem a while ago , I will search it for you ,stay tuned
Old Jan 20, 2011 | 04:10 AM
Cadillac's Avatar
Hey, this is link to the thread, you will see an attached image and it's the relay I meant in earlier post
https://www.jaguarforums.com/forum/s...lights+problem
Old Jan 20, 2011 | 02:09 PM
estunum's Avatar
I'll check that out and get back. Just to make sure, I do get the "Bulb Failure" error on the display center.
scooternva
29
Mar 25, 2025 12:45 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
jtflanaga
Sep 28, 2015 01:55 PM
Tim Goz
Sep 17, 2015 09:11 AM
avern1
Sep 8, 2015 06:25 PM
