Does anyone know any place in the US to buy lowering springs for my 91 xj40
I belong to a Volvo forum, Turbobricks, and they are big fans of just cutting coils. Personally it wasn't my approach when I was building my car as I wanted to stiffen the suspension vs just lowering it.
That being said, if all you wanted to do was lower it for looks cutting a 1/2 coil or a coil might do the trick and worst case scenario is a trip to the yard for another set to put back t stock.
Quote:
what i was thinking.. Originally Posted by mickvic
Cut coils? Lowered ? Unsafe at any speed....
If you were going to make the car unsafe. Might be better off selling it to someone who would enjoy the car and buy a mini truck or a honda.
Don B
close
- Join DateFeb 2014
- LocationCrossroads of America
Liked:15,240 Times in 7,238 Posts
I share the concerns already expressed. With its unique curved front spring setup, a Jaguar XJ40 is probably the last car anyone should try cutting coils on.Originally Posted by Jeh
I belong to a Volvo forum, Turbobricks, and they are big fans of just cutting coils. Personally it wasn't my approach when I was building my car as I wanted to stiffen the suspension vs just lowering it. That being said, if all you wanted to do was lower it for looks cutting a 1/2 coil or a coil might do the trick and worst case scenario is a trip to the yard for another set to put back t stock.
I do seem to recall that Jaguar offered a Sports version of the XJ40 that came with lower springs. Perhaps you could source a set from one of the Jag parts specialists like Coventry West, Jagbits, SNG Barratt, Welsh Enterprises, etc.
The thread at the link below discusses the pros and cons of a lowering spring set available from Arden:
http://www.xj40.com/viewtopic.php?f=24&t=3542
You might also try searching the archives here at Jaguar Forums, and also at the Jag-Lovers.com XJ40 forum.
Cheers,
Don
plums
close
- Join DateFeb 2011
- Locationon-the-edge
Liked:2,201 Times in 1,633 Posts
cutting coils might not be suitable for a Jaguar due to the coil end configuration.
But on a vehicle where it is possible, cutting coils will both lower and stiffen the spring. This is because a coil spring is essentially a torsion bar wound into a coil. The shorter torsion bar increases the rate.
