XJ40 ( XJ81 ) 1986 - 1994
new problem not starting not cranking no lights just a beep
Old Dec 16, 2009 | 12:13 AM
martinvecchio's Avatar
Default new problem not starting not cranking no lights just a beep
after repair almost everything in my car: fuel pump, alternator, transmission relay (causes limp home mode), fuel pump relay, etc etc. i found that this morning when i went to put the key the car did not start.
symptoms:
1-when key is inserted in the door the central locking system is not working
2- just a beep, no lights on the dashboard, no nothing.
3- looks like NO battery at all, will check and post the results.
Martin
Old Dec 16, 2009 | 04:13 AM
Cadillac's Avatar
I think you may need a new battery . Just buy a new one even if starts quickly without any problem during jump start
Old Dec 20, 2009 | 08:43 AM
dimsum29's Avatar
symptoms:
Martin
1.check fusible link / positive wire trace from batt to link (sometimes it to pieces of metal together) may be rusted also
2.did you reconnect ground from engine block
3. have parts available that work dimsum29@hotmail.com 954 298 5602
alt starter , etc ,
Old Dec 20, 2009 | 11:06 AM
Any update Martin? Especially to do with your battery.
fast40driver
Apr 19, 2024 07:24 AM
Drew2006
Nov 24, 2015 11:14 AM
jdzubas
Oct 4, 2015 09:14 AM
1964Daimler
Sep 2, 2015 11:41 PM
cheaperts
Aug 30, 2015 06:48 PM
