XJ40 ( XJ81 ) 1986 - 1994
No fire from coil
Old Feb 26, 2011 | 10:25 PM
BIGBENNETT's Avatar
Default No fire from coil
I recently replace my 1990 xj6 4.0 engine with a 1991 xj6 4.0 engine. I can not get any fire from the ignition coil. I have fire going in though. I have fire going to the injectors. I changed the crankshaft censor. I noticed that their is no fire going to the crankshaft censor. Any suggestions.
Old Mar 1, 2011 | 10:26 PM
Glendoramike's Avatar
Check for the OOPs first. Look and make sure all grounds are in place and making contact, all connectors are in good shape and plugged in good. Check all fuses that supply the engine. I don't have access to the wiring diagram for your car, but look and compare and make sure that the wiring and computers match.
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
Bcrary3
Sep 27, 2015 12:21 PM
reb1999
Sep 26, 2015 08:41 AM
