XJ40 ( XJ81 ) 1986 - 1994
O2 Sensor
Old Oct 25, 2023 | 05:15 PM
Captain Bob 369's Avatar
Default O2 Sensor
I can’t find my O2 sensor on my 4.0, no codes show on the code reader in the car, but I have a check engine light on and most suggest O2 sensor. Can not see it, must it be on a lift to locate it?
Old Oct 25, 2023 | 07:40 PM
Lawrence's Avatar
You can't display codes with the engine running or with key removed from ignition/switched off. With the ignition on, press the VCM button. An FF code number should appear.
The O2 sensor is in the pipe just aft of the manifold/exhaust joint. On top. I wouldn't do anything with it untill you see a code displayed because there are many reasons for a check engine light, a failing oxygen sensor is just one.
ericnunez
Jul 29, 2023 05:07 AM
hoodun
Apr 14, 2016 11:17 PM
nellycolts
Jun 27, 2014 06:15 PM
zibby_uk
Nov 1, 2012 09:41 AM
