XJ40 ( XJ81 ) 1986 - 1994
Peter-AUS
Old Apr 26, 2017 | 03:57 PM
Peter-AUS's Avatar
Default Peter-AUS
The left side repeater light isn't working in my AUS delivered 1987 XJ40 XJ6 3.6L. There's no signal along the wire which points to the LF bulb module being faulty. Does anybody know which relay in the bulb module does the flashing signal for the side repeater light? They're numbered RL1 to RL7(?). Thanks for your help.
Old Apr 26, 2017 | 07:04 PM
avern1's Avatar
Try posting in the xj40 section. This is the x308 and our cars started production in 1997.
Old Apr 27, 2017 | 04:37 PM
Peter-AUS's Avatar
Default Peter-AUS
Old Apr 27, 2017 | 04:55 PM
omgimali's Avatar
Wrong section of the forums but did you check the bulb to see if it is faulty. and did you use a LED bulb?
https://www.jaguarforums.com/forum/xj40-xj81-25/
Old Apr 27, 2017 | 05:18 PM
Originally Posted by Peter-AUS
The left side repeater light isn't working in my AUS delivered 1987 XJ40 XJ6 3.6L. .....
Welcome to the forum Peter-AUS,
I've merged your two identical threads and moved your question from X308 to XJ40 forum. This is the place to post technical questions about your model.
Old Apr 27, 2017 | 07:55 PM
Peter-AUS's Avatar
Hi. Sorry to stuff up the protocol. I often looked at your forum through search links before I joined and when the dialogue box appeared to ask a question - even though I wasn't a member - I jumped at the opportunity! Of course, before I could post my question I was led to the sign-up page. After doing that I discovered that my premature question had already been posted, before I had the chance to introduce myself. Hence, the cart before the horse! Thanks for moving my thread to the XJ40 forum.
Old Apr 27, 2017 | 07:58 PM
Peter-AUS's Avatar
Sorry about the wrong forum. It was a filament bulb with no voltage signal at the bulb housing/socket or the wire to the BRFM.
