XJ40 ( XJ81 ) 1986 - 1994
Power Steering Leak Repair
Old Nov 17, 2013 | 05:59 AM
mrtalkradio's Avatar
Default Power Steering Leak Repair
This first pic is a delightful site, after at least 10 months of an annoying power steering leak. It's finally dry.
That 3 way junction is a Jag special order, no way would I get a used one. The hoses are 20+ years old and hard as a rock. They were made extremely well, cutting them is a task within its own.
At least 2 times in the last 10 months I replaced all the clamps, and have re-tightened to no avail. The connection point at the 3 way junction is within the 3 way tee itself.
What happens is the hoses just start to seep. Everywhere. This isn't at just one connecting point, its everywhere these hoses are. This causes havoc in other places as well. The indentation in the hose fits down under the coil, the connecting point at the filter and upper housing is right above your belts and guess what else? Yes, the dreaded CPS.
Because these are not high pressure hoses, they can be replaced with power steering hoses, but you will have to build your own 3 way junction.
You can't just get one hose ether, you have to buy the whole thing as in the pic, if you decide to get it from Jag.
I used copper plumbing piping. I had to get very creative because one of the hoses coming out of the 3 way junction is smaller than the others.
When doing a job like this, it gives you a chance to clean everything around the coil as well.
It works, power steering feels great again, and I stopped the bleeding.
Attached Thumbnails Power Steering Leak Repair-photo-8-.jpg   Power Steering Leak Repair-photo-6-.jpg   Power Steering Leak Repair-photo-5-.jpg   Power Steering Leak Repair-photo-4-.jpg   Power Steering Leak Repair-photo-3-.jpg
Old Nov 17, 2013 | 11:12 AM
Cadillac's Avatar
Very cool job , I forgot to add in your tool topic , I like your new avatar very exquisite
Old Nov 17, 2013 | 10:28 PM
NTL1991's Avatar
Great info! I think ÜRO PARTS makes a replacement Y-pipe, which is pretty reasonably priced, at close to $50 or so.
The Y-pipe on my 1992 4.0 was replaced during a $1900 "B" Service at the dealer. Ouch! The factory part number is CCC-6573, priced at $164.41, along with $200 labor to replace it.
You've definitely got a great solution to such an annoying issue. And it looks like it'll hold up well, too.
Nick
rusty37
Apr 5, 2020 07:40 PM
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
