XJ40 ( XJ81 ) 1986 - 1994
rear wheel bearings
Old Oct 5, 2007 | 04:09 PM
ken@britishparts.com's Avatar
Default RE: rear wheel bearings
Remove the wheel and then the axle nut. In theory you can slide the hub carrier off the axle. (It's never that easy.) From there you can disassemble the hub carrier and get to the wheel bearings. Keep your spacers and shims in correct order!
Old Oct 10, 2007 | 04:16 PM
Once you have hub in hand it's just like doing the bearings in a Chevy 1/2 ton truck. You know the old races out with a punch or an extension. Use a large socket to seat the new races into place. Do NOT drive against the surface where the bearing will ride. Most parts houses have kits with tools to set races.
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
innzane
Sep 2, 2015 10:08 AM
