XJ40 ( XJ81 ) 1986 - 1994
Rear wheel stud stripped.
Old Nov 17, 2023 | 04:26 PM
P.B.'s Avatar
Default Rear wheel stud stripped.
Just found one of the rear wheel studs missing that I'm quite sure the creep at the tire shop stripped out and didn't bother to come clean and just put the hubcap back on.
Is there any chance of re-tapping the hub and maybe using a helicoil? I'm wide open for suggestions!!! Also, Where would I find another lug nut and stud?
Old Nov 23, 2023 | 09:25 AM
Roger95's Avatar
I re-tapped and installed a helicoil on one right rear stud. It is still holding after ten years. Torque spec is 70 pound feet, I tighten to "snug" by hand and have never had
a problem with the repair. BE ADAMANT with your repair shop, NO IMPACT wrench, torque wrench only! SNG Barratt can provide you with lug nuts and studs.
My best, Roger
oxendine
Apr 29, 2023 10:05 PM
J_C_R
Jun 29, 2022 01:07 PM
cooldood
XJ40 ( XJ81 )
May 13, 2018 01:23 PM
PaulsXK8
Jun 19, 2015 12:47 PM
neil0131
Aug 16, 2012 07:11 PM
