XJ40 ( XJ81 ) 1986 - 1994
running lights not working as they should
Old Aug 18, 2013 | 02:47 PM
Tommy1994xj6's Avatar
Default running lights not working as they should
I have a 1994 xj6 when I turn on the running lights they do not come on most of the time. Every now and then they work fine, most of the time they do not come on. turn signal lights work 100% of the time both front amber lights and rear red turn signals work 100%. Brake lights work 100% when I apply the brake.
Its the running lights both amber front and side marker and both red rear and red rear side marker lights and tag lights work about 20% or less of the time. Any Idea what maybe causing this? I am wondering if it is the light switch it self the lights should work when I put the switch in the first position however they do not. The headlights work 100% of the time when I put the switch in position second position. Any thoughts on what the problem could be?
Old Aug 22, 2013 | 08:06 AM
MidwestJag's Avatar
Tommy:
Keep in mind that I'm not (pun intended, I suppose) the brightest mechanical bulb on the Christmas tree, but... Looking at the diagram on pg 12-22 of Haynes, it seems that there is an aux side lights relay. Not even sure if it applies to your model year, but could that be it? I'm also assuming that you have no blown fuses indicated or that the BFMs are not indicating anything.
Good luck!
Scott
Old Aug 22, 2013 | 11:55 AM
Lawrence's Avatar
Hi - 94's seem to be especially prone to dry or cracked solder joints and if it were my car I'd take a look at the light relay modules and try re-soldering any joints that look suspect ..
see here
http://www.xj40.com/viewtopic.php?f=19&t=6560
good luck
Old Aug 22, 2013 | 11:31 PM
malibudav's Avatar
Check to see if the Cigar light goes out with the runners. If so, it could be a big Multi-Relay located behind the passenger kick panel below the air bag. If you can find a replacement part, its easy to remove/install.
Good Luck
Old Sep 20, 2013 | 05:01 PM
jagnoob's Avatar
i wired my running lights to my fog lights. hasnt failed yet
BrentGardner
29
Dec 16, 2024 12:13 AM
MJ'S Jag
Nov 10, 2022 08:14 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johnnie ryall
Oct 19, 2015 09:44 PM
Jandreu
Aug 29, 2015 07:31 PM
