XJ40 ( XJ81 ) 1986 - 1994
Sovereign Update
Old Feb 15, 2011 | 03:26 PM
mrtalkradio's Avatar
Default Sovereign Update
I drove the new cat home this morning, a good 58 mile ride. I think the steel belted radials in the rear are causing a nice hum throughout the car from 68mph-72mph. I changed the tail lights from the vdp, chased down a notorious orange lightning bolt on the dash, got rid of the bulb out icon on the dash as well. I pulled the antenna out and fixed that motor, I just ordered a replacement antenna. I replaced the switch that turns on the lights under the hood, and put a new key ignition from the vdp. Also changed the main brain by putting in a new battery. I stepped on the brake for 30 second with the battery out. Hooked it all back up and now have a clean instrument panel without any codes. Only thing left is pads, new plugs, distributor and wires, plus oil change.
Old Feb 16, 2011 | 05:22 AM
Cadillac's Avatar
That's good ,have many happy safe driving
Old Feb 17, 2011 | 03:11 PM
The above quote was wishful thinking on my part . Bad LH Rear Wheel Bearing.I do not have the tools nor knowledge to do that job. I will just replace the entire wheel from my other car.
oldjaglover
Dec 25, 2024 04:33 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
aadjei
Sep 25, 2015 03:07 PM
