XJ40 ( XJ81 ) 1986 - 1994
Tach
Old Sep 27, 2011 | 04:00 AM
mrtalkradio's Avatar
Default Tach
Is there any proof that while cranking an engine that won't start, that if the tach is working while you are cranking that your crank sensor is good?
Old Sep 27, 2011 | 10:14 AM
carlosz's Avatar
you should have spark as well if the ckps is good, disconnect your tps it may be wet with oil thus shorting inside and giving the ecu a flood condition where it shuts down the injectors.
Old Oct 29, 2011 | 04:59 AM
Thanks Carlos. I wish there was away to bench test those nasty CPS's
LnrB
Sep 24, 2015 11:16 AM
jagtoes
Sep 9, 2015 09:56 PM
nosox
Jun 20, 2010 04:52 PM
globalxgear
Apr 18, 2008 07:40 PM
