XJ40 ( XJ81 ) 1986 - 1994
Is there any advantage to using 100% synthetic oil?
Old May 11, 2011 | 09:40 PM
Steve W's Avatar
Default Is there any advantage to using 100% synthetic oil?
For instance, can you change your oil every 5000 miles instead of every 3000 miles if you use synthetic?
Old May 12, 2011 | 04:12 AM
Cadillac's Avatar
Yup, that's it and if you drive under extreme conditions you benefited from using full synth than that of dyno oil . I am using full synth at recommendations by Jag mechanic .
Old May 12, 2011 | 08:44 AM
Mikey's Avatar
Why are you changing your oil every 3000 miles?
Old May 12, 2011 | 09:04 AM
Steve W's Avatar
I just got the Jag. I changed my Mazda's oil every 5K miles using synthetic. How often do they reccomend you change an XJ40's oil?
Old May 12, 2011 | 09:37 AM
xjrguy's Avatar
The maintenance interval for the XJ40 was 7,500 miles. If you are going to use full synthetic, I would be content to go the full 7,500 miles. The later cars use 10,000 mile intervals, and personally, I'd be OK doing that with the XJ40. But some folks can't bring themselves to do that. I run full synthetic in my XJR 6 cyl., and I go 10,000 miles between changes.
Your choice!
Scarecrow
Mar 28, 2016 03:17 AM
Tim Goz
Sep 17, 2015 09:11 AM
ratgawd
Sep 16, 2015 04:15 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
teacoff
Sep 10, 2015 08:25 AM
