XJ40 ( XJ81 ) 1986 - 1994
where are the ABS relays located
Old Jun 11, 2008 | 10:38 AM
XJ6_1994_J40's Avatar
Default where are the ABS relays located
Resently I posted (Brake system please help!!!) Ihave been trying to resolve an issue with the system, I have found out that the Pump is working when I place dirrect current to it, which now leads me to believe that there is a Relay in the brakinmg system that is intermitingly working, SEE MY POST ON THE ISSUE. Anyways my question is whre are the relays to the brake system of 1994 jaguar XJ6 located. this is a U.S. car, thanks
Old Jun 14, 2008 | 01:55 PM
JagtechOhio's Avatar
Default RE: where are the ABS relays located
Under dash, LH blower housing, like I told him the first time about a month ago
Old Jun 14, 2008 | 08:39 PM
ibjags's Avatar
lol
Old Jun 18, 2008 | 08:30 AM
found the two relays and will be replacing the acvcumulator relays, The cost is $43,00 from jag. thanks everyone for the information I will keep posted once the system is back and running correctly.
Old Oct 23, 2024 | 08:12 AM
Phewop's Avatar
Default 1994 XJS ABS pump relay location
I see that the relays for the abs system are supposed to be located under the passengers kick panel on my RHD XJS but the previous owner has seen fit to swap quite a few of the relays. I did not have a yellow relay located under the dash. I had a white with black bottom relay there. The yellow relay has larger prongs than the white and black one and it fits in the space where the white relay was. is the first relay on the left supposed to be the yellow relay? Does anyone have a photo of the relay area under the dash for a 1994 xjs so I can see how many relays are wrong?
Rivguy
Nov 13, 2022 02:55 AM
CaneCounsel007
Nov 13, 2015 09:05 PM
driver safz
Sep 18, 2015 08:56 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
leep123
Sep 12, 2015 06:53 PM
