XJ40 ( XJ81 ) 1986 - 1994
xj40 1990 battery flat dead after 3 days
Old Sep 2, 2014 | 11:48 AM
Grooveeblues's Avatar
Default xj40 1990 battery flat dead after 3 days
Hi everyone! Does anyone experienced battery power loss until is almost flat dead while the car is off for at least 3 days? This has being happening for a few months now. Any advice please. Thank you very much.
Old Sep 4, 2014 | 08:29 AM
geridiver's Avatar
There is obviously something still live with the ignition off. One of my rear seat courtesy lights stays on now & again which flattens the battery. Try removing the bulbs in the boot & under the bonnet in case one of them is staying on & also check all other lights.
Old Sep 5, 2014 | 08:10 PM
Rob Evenson's Avatar
you have a parasitic draw on the system. You will need to meter the battery draw at the battery terminals, while pulling fuses from the fuse boxed...one at a time.
Do you have a meter?
Do a search in the XJ40 archives with the words "parasitic draw" as part of the search parameter. Myself and others have written in detail how-to find the circuit causing the problem.
Old Sep 7, 2014 | 11:12 AM
superchargedtr6's Avatar
I literally just went through this with my XJS. It turned out to be a bad battery. Darndest thing. I could charge it, car would start great. But let it sit overnight, and it would be down to something like 7.3 volts overnight, but never flat dead. After spending a lot of time tracking down everything else, I took the battery and had it tested. Exactly my problem.
Old Sep 8, 2014 | 08:32 AM
My apologies for the delay , thanks to all of you for your help. I'll get a multimeter this week to start performing the troubleshooting as told . I am sure it will be an interesting and valuable learning time. I will post again with the results of my search.
Best regards,
Alberto
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
al_roethlisberger
Sep 11, 2015 10:04 PM
OkieTim
Sep 8, 2015 04:48 PM
