XJ40 ( XJ81 ) 1986 - 1994
XJ40 current
Old Jul 10, 2013 | 04:31 AM
bluesway's Avatar
Default XJ40 current
Has anyone any idea why a 1996 XJ40 V12 would have current loss of 3.00 amps at the battery with car shut down i.e: with ignition key removed? The ND Alternator has been checked by 2 independant people & is okay as is its capacitor. The flow stops if the round plug at the rear of the alternator is removed. There is no current flowing at all at the fuses.
Old Jul 10, 2013 | 04:46 AM
jimbov8's Avatar
Replace the alternator, its no good.
Old Jul 10, 2013 | 08:43 AM
+heaps.
If the drain stops with any item "out of the system" then that item is the culprit.
The regulator "leaking to earth" is a fairly common issue, as are diodes leaking.
I am looking for similar on our S Type,and the alternator unplugging was the FIRST item I did, no such luck however, so the search continues.
sg997tt
Oct 9, 2015 10:57 PM
ArtyH
Oct 2, 2015 11:39 AM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
Tally Ho
Oct 1, 2015 01:49 AM
