XJ40 Sovereign Beginner - Hot Engine and Odd Underside
#41
I think that the plate I refer to is best viewed on any part supplier website. SNGBarrats seem to use Jaguars drawings but may be somewhat easier to use than Jaguars. It is on the rear face of the head- facing the firewall above the transmission . It is almost impossible to see at all because of wiring harnesses, the wiper motor, the main air injection tube and at least one vacuum line. I have tried repeatedly to look at mine with bright light, mirror, from the bottom , yadayadayada, and have given up until such time...... As far as the suspected coolant on the steering rack, dont rule a drip from your flush out so fast. its not that far back, and once you take the thermostat housing off, you get stuff running everywhere although you may not see it. Im suggesting you May Not have a problem there. Please get a look at those brakes. The parts arent hard to get or very expensive (at least not in the US). Keep up the good work!
#42
#44
Received 12,833 Likes
Hi Wsz,
I can't remember if anyone has mentioned how common it is for the camshaft cover gasket to seep or leak oil onto the hot exhaust, resulting in smoke and burning oil smell. In my experience, the most common leak point is at the rear of the cylinder head, near the firewall.
Another common oil leak is from the head gasket just above the distributor. The original head gasket did not seal well around a small oil passage in that area and allowed oil to drip down the forward right side of the block below the head.
Regarding the plate on the rear of the cylinder head that Jerry mentioned, Jaguar calls it the "Rear Cover." It is part number 9 in the diagram below. Its gasket is part number 11. The cover is so close to the firewall that it is difficult to see even with an inspection mirror.
You can view the parts diagram here:
https://parts.jaguarlandroverclassic.../brand/jaguar/
Cheers,
Don
Cheers,
Don
beeman
08-12-2018 04:41 PM
