12V +A to +B firewall posts
Old Nov 29, 2024 | 09:26 PM
Jeffkrell's Avatar
Default 12V +A to +B firewall posts
So I was working on removing the Delanaire out of the car and took a look at the cross wire linking the 2 + positive posts.
It looked ok, (not chafed or cracked) but once removed and bent it crumbled.
I see this cable as a big potential for an electrical fire. It is well protected behind the asbestos fire shield yet it won’t take much for it to get in contact with bare metal. I removed it and linked a new cable internally.
anyone else sees or have experienced an issue with this 50 year old hot battery bus cable ?
wont mention the corrosion and resistance produced by it to get to post B.. another source of issues.
Old Nov 29, 2024 | 10:08 PM
Thorsen's Avatar
Did you check the bulkhead pass-throughs too? I replaced both the cable and the bulkhead pass-throughs. If either of those fail and you don't quickly cut the battery power, you're going to be having a bad day.
Old Nov 29, 2024 | 10:20 PM
Jeffkrell's Avatar
Yes those were good. No cracking of the nylon insulation, solid. But almost 50yrs old…
Clackavosticus
Apr 21, 2023 03:19 PM
Barry_Tucker
Sep 25, 2022 01:53 AM
avt007
Aug 14, 2014 01:28 PM
OWRltd
Nov 4, 2013 02:22 PM
98jags
Mar 6, 2013 12:02 PM
